ariel chu
20 points
Posted on - 04/07/2012
Hi friends
I am using Google Chrome as my default browser. I have Skype toolbar installed on chrome.
When i try to search in Google a Popup raised showing me Skype toolbar stopped working, it's annoying me.
Can anyone help me to get out of this.
Thanks
Error with Google Chrome Skype Toolbar
You have to two options to stop getting “Skype plug-in crashed” errors:
You can disable the Skype toolbar thru the Control Panel of your PC — Start> Control Panel>Programs> Uninstall a Program then look for Skype Toolbars then uninstall. Don't forget to reboot your computer after for the un-installation to completely take effect. Or,
You can disable the toolbars via Google Chrome — Options>Under the Hood> Content Settings> Disable Individual Plug-ins. Either way, removing the Skype toolbars (without having to remove Skype from your PC) will solve your problem.
Hi Ariel,
You should disable the Skype plug-in from Chrome.
Please follow this route to do it –
1. Copy Paste this command in Chrome browser – chrome://extensions/ in the omnibar,
2. Press Enter,
3. Following image will appear.
4. Locate Skype plug-in,
5. Uncheck the “Enable” option on extreme right or just press on “delete” dustbin sign available near “Enable” option.
I am sure you will not see the error again.
