While Google Drive (Windows 7 x 64) was a synchronization many files, it stopped with the following error:
'We feel it, Google Drive has to allow smoking.
An unknown problem happened and Google Drive needs to stop smoking. Error: Key main debit to be the only
If you see this error several times, try to disconnect your cuentá
I enclose a screen apprehension.
Error with Google Drive in Windows 7 – 64 Bit
Google Drive is a very important and popular drive, where you can store your important files and applications, and you can use it from any corner of the world with an internet connection.
First, I suggest you check your internet connection, and make sure it doesn’t create any problems for synchronizing files.
Sometimes antivirus and firewalls create these types of problems, so disable your antivirus and firewall for a moment, and try to synchronize again.
I hope this helps you solve the problem.
Hello brother,
Here is also another Techyv page that'll give you more information on various Google Drive error and how to fix them.
10 Common Google Drive Errors
