A few days ago I installed antivirus in my computer but at this time when I search for antivirus it does not show. It gives me this error when I search for antivirus. Help me please.
Problem: You’ve requested the function that requires installed antivirus software.
Without Antivirus software you are very vulnerable to computer viruses, including infected email attachments viruses that attack over the internet spyware that is introduced by virus infections.
An error has occurred with Anti-virus Software
I think your antivirus software exists but does not running.For this,you have got this error message. If you are sure about installing antivirus software in your computer,please check the installed programs in your PC . For this Go StartMenu ->Control Panel->Programs->Programs and features. If you find the antivirus software in the installed programs,you first uninstall the antivirus software and restart your system.Then reinstall the antivirus software in your computer.
Hi Donnaa. Â I think, the problem with your website is not the zoom but it is the pixel. Â Try to check again your website settings and check your pixel resolution. If it is too big, try to resize all the images and fonts including your website backgrounds. You can do trial and error procedure so you can make your website perfect. I hope this information helps.
