An error has occurred in this dialog.
I encountered the following problem when I try to use web form or send data using Internet Explorer. May be due to my browser has been corrupted by any virus or something else. But my question is how can the problem be solved? My internet experience is very bad right this time.
Windows Internet Explorer
Error: 54
Unspecified error.
OK
Wishes,
Magdelina
Best Answer by Sharath Reddy
Answered By 590495 points N/A #90404
That is why I seldom use Microsoft Windows Internet Explorer it generates too much error even if you are not doing anything on the system.
Run a disk check on your hard drive to see if there is an error in its file structures:
  1. Right click on drive C and then select Properties.
  2. Click Tools tab.
  3. Click Check Now button.
  4. Check Automatically fix file system errors and then click Start. Wait for the disk check to finish.
If all seems well after disk checking update your antivirus then run a full-system scan on your computer. If nothing is found on the virus scan, install other internet browser like Mozilla Firefox 7.0.1, the latest version which can be downloaded.
Answered By 0 points N/A #90406
This problem is related to add-on errors on your Internet Explorer.
Solution 1: Try running you Internet Explorer with no add-ons running. To open this you need to click Start, All Programs, then go to Accessories, System Tools. You will see it there, and it says Internet Explorer (No add-ons). Test the same website that the error occurred.
Solution 2: Change your web browser or upgrade your Internet Explorer. You can try using Mozilla Firefox, Google Chrome or Safari. These are the most commonly used web browser of today. Try Using one of those and then run the same website.
Solution 3: You can also try updating your Java because it might be java related error.
