Hi community.
I’m using sun's java standard edition 6 platform on vista with all updates on 32 bit, how to go for 64 + will I need to re-install all soft or can aced etc be switched to 64 anyway, found this error message:
An error has occurred during startup starting jSDN, any idea can be found?
An error has occurred during startup” starting jSDN
Hi
There is a problem in Java Standard Edition 6 with Windows Vista. That why this error occurred every time. And you want to switch to 64 bit version so there is no way to switch to 64 bit directly. Basically bit version decided by Operating System like you have installed Windows 7 64-bit, then you can install only 64-bit supported applications.Â
So you just format your system and remove Windows Vista. Then Install Windows 7 Ultimate 64-bit and install Java Standard Edition 6. You will never again face this startup problem.
Thank You
