An error has occurred with the hack prevention program
After a while of getting the game started, I created a character and the game then got crashed. And then the following ERROR message appears saying,
An error has occurred with the hack prevention program. (Error Code = 10301) The game will now terminate.
Unfortunately, I didn’t find any information in the ERROR CODE 10301.
Anyway, I want to get rid of this. Any idea will highly be appreciated.
Best Answer by Opland Pamela
Answered By 5 points N/A #139127
Hi Janice Emond,
This is problem from Hack shield. You have to delete the hack shield folder from the installed folder. To do that go the folder where you installed the program and then find the hack shield folder in it and delete. After that please try again to start.
Hope you will get better result. Wish you Good luck.
Answered By 0 points N/A #197742
Hello Janice Emond,
I think that problem occured when you are directly executing the game using the exe file. If that game has a launcher try to run it from there. The game might have been updated and the hacking prevention software kicked in because it has detected that your files are not updated. I'm pretty sure that when you launch the launcher it will check for updates first before executing the game.
Hope this helps.
