An error has occurred in iPhoto. The problem has been reported as “Check with the developer to make sure iPhoto works with this version of Mac OS X. You may need to reinstall the application. Be sure to install any available updates for the application and Mac OS X”. Have you ever seen this error report?
Please suggest me on the issue.
Problem Report for iPhoto
iPhoto cannot be opened because of a problem.
Mac OS X. You may need to reinstall all application. Be sure to install
any available updates for the application and Mac OS X.
Click "Send to Apple" to submit the report to Apple. This information is
collected anonymously.
Comments
Show Details Don't Send Send to Apple
Hello Jhon,
That sometimes happens when you are missing a file in the following folder location:
System/library/privateframework/iphotoaccess.framework.
You will therefore need to check that, and then just and then paste your old file in place. After that and iPhoto should be able to start up without any issue.
Nicke
Hi Anderson,
Sometime the library files are missing; in that case you need to check disk utility. After that the iPhoto is able to work.
If after checking of disk utility the iPhoto cannot start work. In that case you need to re-installation of iPhoto. For re-installation of iPhoto follow the listed steps:
1. Put the iPhoto.app in the trash.
2. Go to HD/Library/Receipts and remove any pkg file there with iPhoto in the name.
3. Reinstall.
If you purchased an iLife Disk, then iPhoto is on it.
May be this link is helpful to you.
Hi Dear,
I hope I will satisfy you.
Dear first check that you have properly installed this software on your system?
Was there any file corrupted in the main window?
Sometimes, due to electrical failure or any technical reason, system restarts suddenly. Currently the opened files may be corrupted.
You have need to Run Check Disk utility. If problem remains, then reinstall your software.
The problem will be minimized.
