An Error has occurred with MAX 6.0
I have installed MAX 6.0 successfully. When I start the software the error as in screenshot occurs.
I have installed the interlock drivers. For Windows XP, Vista, and Windows 7. This installer is for both 32 and 64 bit Windows.
I have rebooted the machine and tried it again, but still the same error as in the screenshot.
Does anyone have the solution for this problem? I have no more ideas what I can do to run this software. I am having a paid license for MAX.
This software requires installation of the interlock) R) device drivers and a reboot before running. If you have not installed the InterLok drivers, please download the latest installer from www.paceap.com, run the installer, and reboot your system.
If you have installed the drivers, you must reboot before you can run this software.
OK
