An error has occurred while Intensity Pro was being upgraded
Hi there,
During the installation of Intensity Pro I was asked if I want to make an upgrade of firmware. I thought that may be a good thing so I have accepted. The upgrade and installation begun, but it failed after a short time. Now if I run a new install it fails again and it fails every time I want to install. Does anyone know what happened and how can I install it properly ? Is the new firmware not compatible with Windows 7 ?
Thank you !
An error has occurred that has prevented the firmware on your
Intensity Pro from being upgraded. Try restarting your computer and upgrading the firmware again.
