An error has occurred while playing back
Message of error found in the creative source of mass media:
Creative Media Source
An error has occurred while playing back.
I need to solve this problem quickly. Please, give me a clear orientation soon.
Hi Oraliarfielding,
There could be a lot of reasons for the error message that MediaSource is showing. Most of the time it appears because of faulty or incomplete installation. So, it’d be better if you go for a new installation. Just remove the software from control panel – add/remove software. Then run the setup again.
I hope this will solve your problem.
Hello! I have read your problem. It's happened unexpectedly corruption of your software. I have faced this type of problem. To solve it, I had firstly removed my present version of software. Then, I have reinstall the software. You have to keep in mind that registry should be cleared before installing the new version of software. Best of luck!
