Ricky Dowry
Posted on - 07/28/2011
I finding some helpful tip and solution in the Help and Support Center but when I click some link that will redirect me to Control Panel and some Related Topic link I get this error message. However when I got to my Control Panel to check if it doesn't work but it seems to work fine.
To copy a network connection
1. Open Network Connections.
2. Right-click your dial-up, VPN, or direct Create Copy
Notes
* XOX
Cannot display the page
The page you are trying to view cannot be displayed. This may be because:
* If you are trying to view this content over the network, there may be network congestion or a problem with your connection.
* There might be an error in the page's address.
* The page might not be available.
Please check your network connection to try another page.
shkboss
Error in Help and Support Center when click some link
I hope you have a nice day, I would like to answer link cannot display the page, there are so many steps follow it ordering:
See whether you can view another web page
Enter any other pages example : www.google.com
Reset the modem or the router.
Disconnect the cable that connects the computer to the modem.
Turn off the modem and the router.
Restart the computer.
After your computer has restarted, turn on the modem or the router, connect the cable from the computer to the modem or the router and restart the computer.
Make sure that all network cables are securely connected.
Start Internet explorer.
Delete your browsing history.
Go to Internet Explorer tools = option and delete = Browsing history , Temporary Internet files , History ,form data , cookies
Use Internet Explorer in No add-on's mode.
Tools and click Internet options , click the programs tab and then click manage add-on's and click an-on in Name list , and then click Disable , Repeat step 3 until you identify the add-on that is causing the issue.
Reset Internet Explorer configuration settings
Start Internet Explorer, click Tools, and then click Internet Options.
Click the Advanced tab, and then click Reset.
In the Internet Explorer Default Settings dialog box, click Reset.
In the Reset Internet Explorer Settings dialog box, click Reset. In Internet Explorer 6, click Restore Defaults, and then click OK .
When the settings have been reset, click Close, and then click OK to restart Internet Explorer.
Temporarily disable the internet security suite or firewall.
Check whether windows assigned you an automatic IP address.
Run system Restore.
Install and check by Google Chrome.
