Error with HotSpot Shield Elite Installation
I installed HotSpot Shield Elite, and it went successfully. But when I tried to launch it, I got an error when opened the Folder Options but I could not find where to create an association.
Can someone please send me a step-by-step procedure?
Thank you.
Http://127.0.0.1:895/config/?action=connect&lang=eng&afd=1288016649&afc=43D275EC404…
This file does not have a program associated with it for performing this action. Create an association in the Folder Options control panel.
OK
Answered By 0 points N/A #93695
Go to the Start Control Panel “appearance and themes” In the folder options, choose the File Types tab of the window that pops up, subsequently find the extension you are facing a trouble with. Check for HTM, HTML & Internet Shortcut. For every one, choose it, click modify, check the preferred program Internet Explorer, verify the box "For all the time use the chosen program to open this type of file," and okay.
Moreover, you will probable desire to perform is go Start-Add Remove Programs, choose Set Program Access & defaults from along the left hand side, enlarge Custom, and select Internet Explorer or your preference & the default…this may have also been messed up with your encounter with IE7.
