ronald luna
20 points
Posted on - 05/31/2017
Hi! I was installing Microsoft Office 2010 Trial Version on my system, and it showed me an error that the product key was invalid. I didn’t even enter any product key since I was installing the trial version. How can I fix it?
Error In Installing Microsoft Office 2010 Trial Version
Hello. The error that you’re facing is very common with users of Microsoft Office 2010 Trial Version. Error 25004 is the error you’re facing. This happens when you install the trial version the second time on the same system.
Microsoft keeps track of which systems have installed the trial version, as well as those systems whose trials have expired. So, once the trial is expired, you can’t install the trial version again on the same system.
As far as the fix is concerned, you could use another system to install it or you could try Microsoft 360.
NOTE: If you haven’t installed it earlier please inform so I can look further into the problem.
