Error In Sony Vaio Wireless Switch Is Fixed.
My Sony Vaio wireless switch laptop is not working. What should I do, I tried updating the PC, but nothing worked. Please help me with this issue, do I need to contact the operator in Sony Vaio.
Since the Sony laptop is very sensitive, do the following steps to remove Sony Vaio wireless switch error before doing all these steps make sure your wireless network is on in the PC, go to the control panel then wireless networks for enabling if not enabled:
Try to reboot your system or shutdown and remove the power adapter along with the laptop battery and leave it for some time as it is.
Try again by plugging the AC adapter and also the battery.
Be sure that your wireless switch is on before turning on the laptop.
You will reach the solution of this problem.
