Error with installation wizard while using Unisphere Service Manager
30 points
Posted on - 07/28/2012
Hey all,
I am using Unisphere Service Manager and this is the error I received when I was using the installation wizard. I have followed all the instructions on how to proceed, but that never solved it.
Error: Configuring Control Station
Brief Description: Insufficient permission to run CLI command.
Full Description: The user doesn't have CLI permission on Control Station.
Message ID: 15569322006
Recommended Verify that the user has been granted permission to access the Control Station.
Action:
1) Open Unisphere and log on as Administrator.
2) Select the system in the drop-down system menu, navigate to Settings > Security > User Management
> User Customization for File, and then highlight the user.
3) After highlighting the user account, select Properties, then locate the Client Access section near the
bottom, check CLI Access allowed box, and click Apply or OK.
4) Return to USM, log out, and retry.
If the problem persists, visit EMC Online Support to check other possibilities. Search for knowledgebase
article emc267063.
Any thoughts?
Thanks in advance.
