Error Installing ESRI ArcGIS Server Java Plug-in in Netbeans 7.x
Hello TechyV buddies!
I am having some problems with my GIS. I have installed Netbeans 7.0.1 because I wanted to use ESRI ArcGIS Server java Web ADF Plug-in in it. However, after following the installation instruction, it failed to finish its installation because of this problem:
“Some plugins require plugin Editor Library to be installed. The plugin Editor Library is requested in version >= 1.9.22.1 (release version 1) but only 3.9.1.13.10 (of release version different from 1) was found. The following plugin is affected: **ESRI ArcGIS Java ADF web controls NetBeans Module.”
Can you tell me what was wrong with the installation that I have done? I am looking forward for a good solution to my problem. Thank you!
