shara reese
Posted on - 01/22/2012
When I attempt to install the Exchange Server 2003 with Win 200 domain an error message is coming which displays that ‘It is not able to contact the Windows Active Directory due to the error occurred in the set up’.
Please help me fix the problem.
Thanks in advance.
Error in installing Exchange Server 2003 with Win200 domain
I think you need to see the system requirements. This is the issue of system requirement
Component
Requirement
Recommendation
Processor
133-megahertz (MHz) or higher processor
733-MHz or higher processor
Operating system
Microsoft Windows 2000 Server, Windows 2000 Advanced Server, or Windows 2000 Datacenter Server with SP3 or later
Windows Server 2003 R2, Windows Server 2003, Standard Edition; Windows Server 2003, Enterprise Edition; or Windows Server 2003, Datacenter Edition
Note: Exchange Server 2003 does not run on 64-bit editions of Windows Server 2003. Exchange Server 2003 management tools for remote administration can be installed on a computer running Windows XP SP1, Windows XP SP2, Windows Server 2003, or Windows Server 2000 SP3.
Windows Server 2003
Memory
256 megabytes (MB) of RAM
512 MB of RAM
Available hard-disk space
You need:
500 MB on the hard disk where you install Exchange Server 2003
200 MB on the system drive
You need:
Drive
CD drive
CD drive
Display
VGA or higher resolution monitor
Input device
Microsoft Mouse or compatible input device
File format
Disk partitions must be formatted for the NTFS file system, not the file allocation table (FAT) file system. This requirement applies to:
System partition
Partition storing Exchange Server binaries
Partitions containing transaction log files
Partitions containing database files
Partitions containing other Exchange Server files
Disk partitions must be formatted for the NTFS file system, not the FAT file system. This requirement applies to:
System partition
