If you are using Windows XP, then Log on as Administrator and try installing the program.
If you are using any Windows Server edition, then you will also have to log in as Administrator to install the program.
If you are using Windows Vista or Windows 7 then try installing the software by right clicking the main exe/setup file and choosing the run as administrator option.
If this does not work in windows Vista or 7, then you may have to set the compatibility of the software and then run the program as administrator.
To set the compatibility, right the main setup file and click properties. Click the compatibility tab.
Click & choose the compatibility mode as Windows Service pack 2 and from the bottom click the run as administrator mode.
Since you want to install the software for your HP printer, you need to be logged in with an administrator account. Because printer software requires modification to the operating system or it will create global changes to the platform, a user account with administrative privileges is required. You cannot use a standard account to install the software because it will not work.
HP Photosmart D7100 printer
Standard user accounts in Microsoft Windows can only install basic applications because simple programs like these will not modify part of the operating system. If you don’t have an administrator account, ask someone that has administrator account to install the printer software for you. Also, make sure you are installing the software on the right platform.
The driver for the HP Photosmart D7100 printer supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. If you need to download the software again, go to HP Photosmart D7100 Printer Series and download the driver. On the download page, select your correct operating system.
1....
