Error installing internal build to visual studio 2008
Hi guys
I have recently been trying to install the latest version of the internal build to my visual studio 2008. I was able to install it successfully. Despite the successful installation I keep on getting some error messages every time.
The screenshot of the error and of the successful installation are attached below:
Encounted a problem
Microsoft Visual Studio
Microsoft Visual Studio has encountered a problem and needs to close.
If you had files open that contained unsaved changes, these changes might be lost.
Restart Microsoft Visual Studio
Send and error report to Microsoft
A report has been created that includes more information about the causes of this error.
Submitting this report Microsoft improve Visual Studio.
What information is contained in this report?
Debug                                            Send Error Report        Don't Send
telerik ultimate for .net
When I select the option of restarting Microsoft visual studio and submit the report to Microsoft, nothing happens and the installation is successful. I think there must be a bug in the program because it happens with other installers of telerik also.
I require hearing some suggestions from you all.
Looking forward.
Regards
Johnson
Answered By 5 points N/A #141353
Dear,
Microsoft Visual Studio and Telerik needs minimum configuration for proper installation. Please check your computer configuration. If the configuration is ok then try to setup your windows again. You must check the installation CD/DVD that you using should is ok or not. Sometimes CD/DVD has missing files. You can also copy the entire installation file in your computer memory before start installation and install it from your saved files.
In order to get error solution from Microsoft proper windows installation and internet connection is needed.
Thank You.
