Error installing Latest Version Of Ovaldi. Missing MSVCP100.dll
Hey there!
I just installed the latest version of Ovaldi after which I scanned my computer. After a couple of seconds a “Missing MSVCP100.dll” appears. I can’t seem to find a solution for this problem and I’m hoping someone can help me out.
 The dll file is not in the installation folder.
The program can't start because MSVCP100.dll is missing from your computer. Try reinstalling the program to fix this problem.
Help me resolve
Regards
Thanks
Best Answer by Yolada Bron
Answered By 0 points N/A #123684
The missing .dll file might have been quarantined or deleted by the antivirus scan. This was done only for the purpose that the computer is kept secured from the malware or virus that was present with the affected .dll file. You can do one thing. Open the Internet explorer then browse through the web for the missing .dll file and then download it. Copy the file to the directory from where it is missing. Now you may find some other .dll files missing. Copy all of them to their correct destination. Now open the executable and then try to make it work. Thanks.
Answered By 10 points N/A #123687
DLL file missing means there is lack of system files in your PC. In this Techyv page, you'll find other ways to solve your issue easily.
Game won't play on windows 8.1
