Hi. Can someone help me in installing mahjong dimensions for blackberry curve? It displays not enough memory error. I checked my phone and it still says 100mb memory still free. The file size of the game is only 31.33mb. What gives?
Error in installing Mahjong dimensions for blackberry curve
The best way to increase your memory and to avoid that kind of problem is to use a memory card for your phone. Most blackberry phones use microSD card. Buy the highest memory capacity if you want to install or save a lot of data in your phone. If you don’t want to use a memory card, restart your phone frequently, clear your call logs and delete old messages that are not important, and uninstall the files that you are not using.
