Error installing Photoshop in my computer
 A few days ago i can use this software properly but now a days when i go to install Photoshop in my computer i got a error message below this
Setup Error:
Setup has encountered an error and cannot continue. Contact Adobe Customer Support for assistance.
Internal Error 2739.
Answered By 0 points N/A #130586
The problem is done with most of the specifications at the people understanding.
The main cause to it is that the software has performed some error that it cannot recover and needs to quit. As such you need to delete the existing installation and then try it once more after proper un installation. Check that the registry does not contain any information about it (regedit.exe). The issue may be placed at forums for the cause. The problems arise sometimes because of new software that is installed and creating problems. The current antivirus and shield may make further problems for the purpose.
