Error Installing PowerCLI On Installed Windows 2008 R2 server
Hi guys.
Today I was trying to install PowerCLI on a fresh installed Windows 2008 R2 server.
Hi guys.
In order to fix this problem, you must delete one of the Registry keys on your computer. Please perform the following ways given below to solve this issue.
1. First and foremost, please go to Start button on your Windows screen and search for Run.
2. Next, type regedit in the data box and then click OK.
3. Once the Registry Editor window popped up, please navigate to the following registry key :
HKEY_LOCAL_MACHINESOFTWAREWow6432NodeVmware,Inc.
4. After that, right-click on the registry key and select Delete.
5. Finally, quit the Registry Editor window and reboot your system.
The PowerCLI setup should now finish and run properly with no
errors.Â
