grecy09
Posted on - 06/17/2012
I’m having some trouble with the publish function of my compiler page. When I try to use it, it starts off okay, but after reaching more than 50% in the progress bar it ends there.
I get an error report seen below.
"Connection Error: Server responded with a failure code -0. Click
Ok to retry."
Does anyone have an idea to fix this?
Thanks
Error Installing Publish Function Of My Compiler Page.
It seems that the problem here is with the application if not with your internet connection. If the program is currently active, try closing it then restart your computer and then try it again. See if the result is the same. If the result is just the same, check your internet connection first if it’s stable. Open your web browser then visit some web sites. You may also try watching some streaming videos just to check the current speed of your connection.
If after checking your connection it turns out to be ok, then maybe the application is not working very well. Try reinstalling it. Uninstall your application then check your computer for any possible errors. Use a disk utility application to check the system. Install the program again after this then check if this fixes the problem.
