Error in Installing S.A.P software on windows 7
I was trying to installing S.A.P software complete with Administrative rights on windows 7 OS yesterday but it refused to install several times after that trying again and again at last it’s start installing but OMG that again stuck with an error that says “incomplete installing reboot and re-install”.
Can anyone help me for Installing in complete details SAP software on windows 7.
With regards.
Best Answer by Darren Mac
Answered By 0 points N/A #84043
Hello Anil,
Well there can be various reason why it did not install correctly. So I would suggest you to follow the steps given below and am sure it will be installed perfectly.
First of all partition your Hard Drive, do a small partition of 9 to 14 GB especially for installing programs, store all your data at different locations/drives. Now backup your OS and then install SAP. I am sure this will work. Also you can use Virtual Machines like VMWare to install SAP. Good Luck.
Thanks!!
Answered By 15 points N/A #84044
The error message says that the installation refuses to complete, and therefore the reason why it is happening that way is possibly because of the following reasons:
  • The application does not meet your computer specifications, meaning that it is incompatible to the current operating system that you are using on the computer. And therefore you will need to get the right application that meets the current system requirements and install it.
  • The application setup may also be corrupt, and therefore lacking some important components that are required for it to finish the installation process. If that is the case, then you will need to search for another application and install it.
-Clair Charles
Answered By 590495 points N/A #327992
Whenever you install a software, check the system requirements first then verify that your computer meets those requirements. SAP stands for “Systeme, Anwendungen und Produkte in der Dataverarbeitung” which is in German and translates in English to “Systems, Applications and Products in Data Processing.” By definition, SAP is also the name of the ERP software or Enterprise Resource Planning.
It is also the name of the company. SAP Software is a European multinational company founded in 1972 by five former IBM employees: Wellenreuther, Hopp, Hector, Plattner, and Tschira. SAP SE is a multinational software corporation and is currently the market leader in the enterprise resource planning field or ERP.
The company currently serves over 180 countries and an estimated seventy seven percent (77%) of the money exchanged via global business transactions touches a SAP system. The company launched SAP HANA in 2011, an in-memory database platform and the forefront of the company’s future strategy.
