I started using my ConfigMgr 2012 administrator console without opening it as Administrator.
When I am trying to correct a report, I get the following error message:
Report Builder 2.0 is not installed as a click-once application on
report server 'ctcmOl.coretech.intra'. Go to
'http: //www. microsoft .com/downloads/details. aspx?displaylang=e
n&FamilyID=66ab3dbb-bf 3e-4f46-9559-ccc6a4f 9dc 19' for
download information.
I really need to fix this. Please help me out.
Error installing SQL Reporting Builder 3.0 in ConfigMgr. 2012
Just try visiting the link that is provided in the error dialog box and see where it goes to. If it points out to a new download information, read the information carefully and the proper installation procedure before downloading the installer. If it requires you to install Microsoft .NET Framework then download and install it on your computer.
You may also try checking your computer for any possible errors. Use a disk utility application when checking the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit. Any errors in the hard drive’s file system can cause problems to applications.
