Error in installing Tivoli Device Driver
Hello there!
Is there someone who can help me to install Tivoli storage driver on my computer.
I get the following error during the driver installation wizard.
I looked up the error log file in windows folder which shows the following messages:
ERROR: RETURN UpdateDriverForPlugAndPlayDevices. (Error code 0x2: The system cannot find the file specified.)
ERROR: Installation failed. (Error code 0x2: The system cannot find the file specified.)
ERROR: PnP Install failed. (Error code 0x2: The system cannot find the file specified.)
Device Driver Installation Wizard
Cannot Complete the Device Driver Installation Wizard
Errors were encountered while installing the software For your devices. See the Status column For more details.
Sometimes it helps to run this wizard again. If that doesn’t work, contact your device vendor.
Driver Name Status
X IBM Corporation (tsmscsi) MediumCh… Install Failed
