Error Installing VMCLite V 3.2.1 In Windows 7 Pc
Hi guys,
I’ve got a problem. I was using VMCLite V 3.2.1. But I just reinstall this on Windows 7 in my Pc. When I plug the modem in, it installs for a certain time. Therefore an error message appears:
Error 2932. Could not create file.
C:windowsInstaller{B5761811-28F3-4257-B537-815 C5EEF472C}1033.MST form script data. Error: 32
OK
Thanks!
Answered By 5 points N/A #83253
Hi KGonzales,
"Could not create file from script data" A.K.A "Error 2932" may be caused by several different reasons, The first of those is the lack of free space. So first make sure you have enough free space on your device and try again.
This also can happen because the temporary folder that this installer creates was not cleared in last uninstall. So you may need to do it manually and here is how:
Go to Start > type RUN and press enter > in the open box type C:windowsinstaller > a folder is opened where you need to find the {55761811-26F3-4257-65337-815C5EEF-472C} mentioned in your error message and delete it.
That's it you can try to launch your installation again now.
Hope this helps.
