Error with Internet Explorer 9
I am at work and we have a intranet that has some files on it we use. When I go to open a file it comes up with this error message. Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience.
For more info on this error, click here give me.
Error Signature: AppName: iexplore.exe AppVer: 6.0.2900.5512 ModName: kernel32.dll
ModVer: 5.1.2600.5512 Offset: 00012aeb
How can I solve the problem?
Best Answer by Stephanie Clar
Answered By 0 points N/A #142059
I believe, in spite of you're a laptop newbie or a laptop technician, you need to have ever received the on top of net Explorer error message whereas surfing on-line. Those will happen frequently on the most recent version of net Explorer – net Explorer 8. However the steps here can show you ways to repair common net Explorer 8 issues quickly.
When encountering net Explorer eight issues, you'll restart the pc. Such reasonably net Explorer issues might solely be owing to minor glitches since it's a platform that has been designed extraordinarily well. Restarting the pc might most likely resolve the matter since the settings and different files and choices get refreshed once the reboot. Sometimes, the net Explorer 8 can happen when it's not properly set-up. So, once a restart, you ought to check & restore it back to the default settings.
  1. Open net Explorer.
  2. Click Tools -> Internet possibility -> Advanced -> Reset.
  3. Check box and named Delete personal settings, and then click Reset button.
In some things, you'll have file corruption caused by malware or by an epidemic existing on the laptop, inflicting the net Explorer to run improperly. When the Windows cannot recall the required files to load the IE 8 on your laptop, then it will fail to show your visiting page and show a web Explorer 8 error message. So, do keep in mind to own an antivirus anti spyware program to safeguard your laptop at any time.
Also, you'll begin Windows in safe mode and take a look at to put in it once more. There should be software that forestalls installation existing on your laptop. To induce into safe mode, you ought to press F8 key on your keyboard before Windows starts and then choose safe mode with networking from the menu. Once you're within the safe mode, you'll download and reinstall IE 8 once more to visualize whether or not you're successful.
However, if the matter remains once a reinstall job, perhaps you have got to pay many minutes to repair Windows registry errors. Whenever you progress a file from one location (folder) to a different or install a driver/program on the pc, an entry is made within the registry, it tells the pc where to seek out the file and the way to run the program properly.
However, invalid or corrupted entries conjointly occur when, for example, you uninstall a program incompletely from your Program Listing within the management Panel. Even if the program itself has been far from the pc, the registry entry that told the pc where to seek out the program continues to be left there in Windows registry, cluttering up the registry and inflicting net Explorer 8 issues whereas you're viewing some pages.
To sum up, though net Explorer 8 issues are inevitable, you're ready to forestall & fix them with some straightforward solutions.
Answered By 0 points N/A #142060
I can help you with the Internet Explorer error on your computer. I suggest you to make sure you are using the latest version of the Internet Explorer on your computer. If you are using the latest version, try the following troubleshooting steps:
>> Make sure the computer’s date and time is correct.
>> Try enabling the Smart Tag from Tools > Internet options > Advanced > Enable Smart Tags.
>> Make sure you are able to browse without any error on any other browser.
>> If the issue still exists, try reinstalling the Internet Explorer on your computer.
Alternatively, you can contact Microsoft support at the webpage www.microsoft.com
Thanks and regards,
Skarbos Jay.
