Error: Internet Explorer cannot display the web page
Hi TechyV buddies!
One of my clients has encountered a problem using Internet Explorer. I have two CMSMS websites that have displayed this error:
“Internet Explorer cannot display the webpage”
I have tried to open websites using IE 5.5, 6, 7, 8, and 9 and found no issue. I have never seen any problem using those Versions of IE in opening the websites. I have checked the debug log and found no suspicious activity or any error. The two websites are both on the same shared hosting server.
I did not encounter this kind of error before neither has altered any properties of the sites for many weeks. Some of the clients never encountered this kind of problem but only one of them experienced this. An old bug thread was found (viewtopic.php?t=19430) but this did not solve the issue. Can anyone help me solve this issue? Here are the following CMS information: Cms Version: 1.10.3
Installed Modules:
CMSMailer: 2.0.2
FileManager: 1.2.0
MenuManager: 1.7.7
Packages: 1.1
ModuleManager: 1.5.3
News: 2.12.3
Search: 1.7
ThemeManager: 1.1.4
AceEditor: 0.2.4
AdvancedContent: 0.9.3
GBFilePicker: 1.3.2
FormBuilder: 0.7.2
Captcha: 0.4.5
CGExtensions: 1.28.2
CGSimpleSmarty: 1.5
CGSmartImage: 1.8.2
Gallery: 1.5.3
TinyMCE: 2.9.6
SEOTools2: 1.0.10
ListIt2: 1.1
EventsListing: 1.1
Config Information:
php_memory_limit:
process_whole_template: false
output_compression: false
max_upload_size: 5000000
default_upload_permission: 664
url_rewriting: mod_rewrite
page_extension:
query_var: page
image_manipulation_prog: GD
auto_alias_content: true
locale:
default_encoding: utf-8
admin_encoding: utf-8
set_names: true
Php Information:
phpversion: 5.2.17-pl0-gentoo
md5_function: On (True)
gd_version: 2
tempnam_function: On (True)
magic_quotes_runtime: Off (False)
E_STRICT: 0
memory_limit: 128M
max_execution_time: 30
output_buffering: 4096
safe_mode: Off (False)
file_uploads: On (True)
post_max_size: 6M
upload_max_filesize: 5M
session_save_path: No check because OS path session_use_cookies: On (True)
xml_function: On (True)
Server Information:
Server Api: apache2handler
Server Db Type: MySQL (mysql)
Server Db Version: 5.1.61
