Malcolm
Posted on - 10/15/2011
I am using new Intrepid 8.10 Ubuntu but in previous days there was a problem that when I right click on my top gnome panel and click on Properties, it brings up the window and an error message. Error message: Error stating file '/tmp/evince-6347': No such file or directory and. So please anyone tell me what is the problem and how to fix.
Error in Intrepid 8.10 Ubuntu
To solve this problem you need new module for panel properties. There is an output module for the panel properties that shows files and folders. May be for some reason that module is crashed. If you have those modules then install it from backup. If you can not install it then restore or repair your ubuntu.
You can also use other updated version as replacement for ubuntu 8. There are two versions after ubuntu 8. Ubuntu 9.8 and ubuntu 10 is the quality full versions. These versions have total module and they open files and folders easily. Also you can update your current ubuntu 8.
