ERROR INVALID DATA 13 The data is invalid
I got this Error 13: data is invalid. It won’t install my on-board soundcard. What should I do?
Any more suggestions are very much appreciated.
Dear friend King, actually you are installing a data is simply an invalid and this error also says that there should be a proper file which must be valid and possess no any viruses. You must install antivirus or use antivirus because sometimes because of viruses some files show an error which create a problem when one is going to open a file.
I can see that your installer might be corrupted. If you still have your recovery disk, try using it first in order for your issue to be resolved. If you don't have your recovery disk or if you do not have a driver disk which came with your system, try downloading the driver software. First, know the name as well as the version number of your installer, and try to manually look for it over the net, and install it on your system. If all your efforts fail, install a newer version of your operating system, as it would be much easier for you to locate an appropriate driver for your device.
