ERROR INVALID PARAMETER 87 One of the parameters was invalid
I cannot update the databases of my Kaspersky. Old database still shows. Is there a way to manually update it, copy files to certain folders like that?
I have read something about editing the C:Program FilesKaspersky LabKaspersky Administration KitSharePackagesKavWks 6.0.4.1212execkav6mp4.kpd
Here the file contents:
[Product]
Name=KAVWKS6
LocalizedName=Kaspersky Anti-Virus 6.0 for Windows Workstations MP4
RegKey=KAVWKS6
AdaptedProduct = 1
[Setup]
UseWrapper=1
ExecutableRelPath=EXEC
Params=/s /v"/qn AKINSTALL=1"
Executable=SETUP.EXE
RebootDelegated = 1
RebootAllowed=1
ConfigFile=installer.ini
[SetupProcessResult]
Wait=1
DescriptionFile=avpsetup.rep
DescriptionFileU=avpsetup.rpu
[SetupProcessResult_SuccessCodes]
0=Installation completed successfully.
1641=Installation wizard started system reboot.
3010=A reboot is required to complete the installation.
[SetupProcessResult_ErrorCodes]
13=The data is invalid.
87=One of the parameters was invalid.
120=This function is not available for this platform. It is only available on Windows 2000 and Windows XP with Windows Installer version 2.0.
1259=The user cancelled installation.
1327=Wrong drive specified.
1601=The Windows Installer service could not be accessed. Contact your support personnel to verify that the Windows Installer service is properly registered.
1602=Installation cancelled by the user.
1603=Fatal error during installation.
1604=Installation suspended, incomplete.
1605=This action is only valid for products that are currently installed.
1606=Feature ID not registered.
1607=Component ID not registered.
1608=Unknown property.
1609=Handle is in an invalid state.
1610=The configuration data for this product is corrupt. Contact your support personnel.
1611=Component qualifier not present.
1612=The installation source for this product is not available. Verify that the source exists and that you can access it.
1613=This installation package cannot be installed by the Windows Installer service. You must install a Windows service pack that contains a newer version of the Windows Installer service.
1614=Product is uninstalled.
1615=SQL query syntax invalid or unsupported.
1616=Record field does not exist.
1618=Another installation is already in progress. Complete that installation before proceeding with the new one.
1619=This installation package could not be opened. Verify that the package exists and that you can access it, or contact the application vendor to verify that this is a valid Windows Installer package.
1620=This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package.
1621=There was an error starting the Windows Installer service user interface. Contact your support personnel.
1622=Error opening installation log file. Verify that the specified log file location exists and is writable.
1623=This language of this installation package is not supported by your system.
1624=Error applying transforms. Verify that the specified transform paths are valid.
1625=This installation is forbidden by system policy. Contact your system administrator.
1626=Function could not be executed.
1627=Function failed during execution.
1628=Invalid or unknown table specified.
1629=Data supplied is of wrong type.
1630=Data of this type is not supported.
1631=The Windows Installer service failed to start. Contact your support personnel.
1632=The temp folder is either full or inaccessible. Verify that the temp folder exists and that you can write to it.
1633=This installation package is not supported on this platform. Contact your application vendor.
1634=Component not used on this machine
1635=This patch package could not be opened. Verify that the patch package exists and that you can access it, or contact the application vendor to verify that this is a valid Windows Installer patch package.
1636=This patch package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer patch package.
1637=This patch package cannot be processed by the Windows Installer service. You must install a Windows service pack that contains a newer version of the Windows Installer service.
1638=Another version of this product is already installed. Installation of this version cannot continue. To configure or remove the existing version of this product, use Add/Remove Programs on the Control Panel.
1639=Invalid command line argument. Consult the Windows Installer SDK for detailed command line help.
1640=Installation from a Terminal Server client session not permitted for current user.
1642=The installer cannot install the upgrade patch because the program being upgraded may be missing or the upgrade patch updates a different version of the program. Verify that the program to be upgraded exists on your computer and that you have the correct upgrade patch.
1643=Service pack is not permitted by system policy.
1644=One or more customizations are not permitted by system policy.
1645=The Windows Installer does not permit installation from a Remote Desktop Web Connection. For more information, see Remote Desktop Web Connection. in the Terminal Services section of the Platform SDK.
[SetupProcessResult_WarningCodes]
[SetupProcessResult_FailReasons]
120=18
1601=5
1612=5
1613=23
1618=24
1619=25
1620=25
1622=28
1623=26
1625=27
1631=5
1632=5
1633=18
1635=25
1636=25
1637=23
1638=19
1643=27
1644=27
[SetupMainResult]
File=setup.log
Section=ResponseResult
Value=ResultCode
FailReasonValue=FailReason
[SetupMainResult_SuccessCodes]
[SetupMainResult_ErrorCodes]
100=Fatal error during installation.
[SetupMainResult_WarningCodes]
50=Warning during installation.
[SetupRestart]
File=setup.log
Value=RebootZombieFile
[IncompatibleApps]
TxtFile=incompatible.txt
CanUninst=1
IncompatibleUninstIni=installer.ini
IncompatibleUninstSection=Settings
IncompatibleUninstKey=RemoveIncompApp
[Version]
VerMajor=6
VerMinor=0
VerBuild=4
VerPatch=0
PluginVersion=6.0.4.1212
DisplayVersion=6.0.4.1212
[UpdInfo]
Folder=Bases
UrgComponentsSection=UpdComponents
Build=1212
[UpdComponents]
BLST2=
CORE=
KAV2006EXEC=
Updater=
KDB=
EMU=
ARK=
WA=
BB2=
RM=
AS=
PAS=
ASTRM=
APU=
ADBU=
AH=
WMUF=
[UrgUpdComponents]
BLST2=
KAV2006EXEC=
AH=
It is too confusing for me.
Can anyone help me on this one?
