Error – Iso26-movefiledata-1 While Installing Drivers
Silva Lewis 10 points N/APosted on - 02/16/2017
I am currently using Windows 7 on my PC. I was trying to install one of the drivers for my hardware, when suddenly I encountered with the follow error – iso26-movefiledata-1. How can I solve this error?
It seems you are installing the driver for your Brother printer but unfortunately the entire error message is in a different language. I hope you translated it in English before posting. Anyway, since the error was caught during the installation of a printer software, what you should do is check if the software is compatible with your computer particularly your operating system.
Since the error is preventing you from installing the printer software, just try downloading the driver from the official website. Go to Brother Support and Downloads then enter the model number of your printer in the search field. You can find the model number on the side or at the bottom of your printer. Another way is to select a product category from the page.
Once you located your printer, select your current operating system from the list. The software for Brother printers are available for Microsoft Windows, OS X, and Linux so make sure you select the correct operating system family to display the list of versions. For Microsoft Windows, make sure you select the correct platform architecture like 32-bit or 64-bit. Click “Search”.
Brother printer software select platform
On the next page, click “Full Driver & Software Package” to download the complete package of the printer software.
1....
