Error launching Lord of the Rings Online
Greetings!
I can’t launch my Lord of the Rings Online (LotRO), can someone help me with this? I recently reinstalled LotRO, but every time I open the launcher it crashes and posts a long error message.
 I don’t know what to do, and I’m hoping someone can guide me.
I will be forever in your debt if you help me out.
Thank you!
Answered By 590495 points N/A #125341
I wish you also include what version of Windows you are using so we can determine the real source of the problem. Since this is the case here, just quit the program, restart your computer and then try it again. A much fresher system will help in the initialization process of the game client. See if this works.
If it’s still the same, maybe the game client is not installed properly. Try doing a clean installation of the game client to restore it to its default configuration and fix any corrupted files that may have developed when you first installed it. Uninstall The Lord of the Rings Online then check your computer for any possible errors. Use a disk utility application to check the system. Install the game client again after this and then check if this fixes the problem.
You should also check if your operating system is compatible with the game. The Lord of the Rings Online only works with Windows XP and with Windows Vista. So, if you are using Windows 7 or any older or newer versions of Windows other than the two [2] supported platforms, you may consider changing your operating system or run the whole game in a virtual machine. For a clearer view, you may visit The Lord of the Rings Online Community Beta — System Requirements.
