mozilla
Posted on - 07/23/2011
I have a newly bought MACBOOK AIR. There is a problem wherein, when I tried to start an Adobe application the message "Licensing for this product has stopped working." error pops up. I know that all of my software are licensed.
Can anyone give me a solution to fix this problem?
vtech
Error “Licensing has stopped working” | Mac OS
Try to do a Time Machine Restore for”/Library/Preferences/FLEXnet Publisher/” and “/Library/Application Support/Adobe”.
After completing the restoration, try to open the adobe application and see if it works.
If still you get the same issue, check if you still have Read & Write Permissions for Adobe. You can find it in the folder for adobe (/Library/Application Support/Adobe).
Lastly, Adobe has a Licensing Repair Tool for Mac Users. Make sure you close all running Adobe applications before proceeding. Download, extract and follow the provided on-screen instructions for the License Repair Tool.
After completion, start your adobe application.
It should work now.
Good Luck! keep me posted!
