An error of Live Essentials
Hi guys, I've got some problems whenever i try to install the newest version of Live Essentials in my pc. I tried to reinstall it for several times, but in vain. And every time I just get a message and that is:
If you could not install Windows Live Essentials on your computer try restarting your computer and then try it again. If the next attempt is another failure, try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton System Works or Norton Utilities. These tools have reliable disk diagnostic features that can analyze and fix different partition and file system errors. When the disk check is finished, try installing Windows Live Essentials again.
Download the right version of Windows Live Essentials for your operating system. It is possible that this is the reason why you can’t install it. Like for example the Windows Live Essentials 2011, you can not install this one on Windows XP. This version of Live Essentials is only compatible with Windows Server 2008 Service Pack 2, Windows Server 2008 R2, Windows Vista Service Pack 2, and Windows 7. Visit Microsoft’s web site again to find the right version for your operating system.
