Hello! I have a query with regards to Integration Manager SAP Connect.
I have been trying to install it in my Windows XP computer but always end up with error below.
The install went successfully but when trying to start it, the error is appearing.
Am I missing something with the installation process?
Please help.
Load Error
Error loading Connector(s): SAP, SAPService
Enabler status error:
Enabler: SAP;Error: Cannot get build for: com.sssw.b2b.ee.sap.rt.GNVSAPXObjectFactory
Enabler: SAPService; Error: Cannot get build for:
com.sssw.b2b.ee.sap.rt.GNVSAPServiceXObjectFactory
Error in Loading Connectors in SAP Service
Hi Stanley,
I'm sorry to hear your problem.
You can perform the solution below to be able to fix your problem:Â Â
From the SAP site, download jco-ntintel-1.1.04.zip into an arbitrary directory {jco-install-path}.
Unzip the file jco-ntintel-1.1.04.zip into an arbitrary directory {jco-install-path}.
Add the DLLs to the extend5ComposerDesignerbin directory.
Add sapjco.jar to the exteNd5ComposerDesignerlib directory.
Add [PATH]exteNd5ComposerDesignerlibjCO.jar to the application server's CLASSPATH
Zorian
Hello Stanley,
It looks like you are having a problem loading connectors in SAP service.
You can follow the below mentioned steps to get a solution to your problem.
1. Go to the SAP site and download jco-nintel-1.1.04.zip into any of your drives or directory.
2. Unzip the file into the same location.
3. Add dlls to the extend5composerdesignerbin directory.
4. Add sapjco.jar to the extend5composerdesignerlib directory
5. Add the file jco.jar to the application servers path.
I hope this would solve your problem.
