evolance
Posted on - 07/22/2011
I receive a message Error Loading Kernel. You must reinstall Windows.
It's kind of weird and happens every time. I think I deleted something on the files registry accidentally and can't find the answer or solution ? I hope someone can help me in resolving this case since I don't want to reinstall my windows because I've got important files inside.
Any help would be appreciated.
Error Loading Kernel. You Must Reinstall Windows
In Such cases it is very difficult to do so if you do not want to re-install the operating system again. You can try taking a chance of repairing the windows. But I guess this will not help. The only solution here is to re-install the operating system. But I can give you a solution to save your files as you don’t want to lose them.Â
Just shift all your data that you have in your drive in which operating system is installed. Because which re-installing the only the drive which contains windows will be formatted. You can keep data in other drives. When you re-install just the windows drive will be formatted and not all the drives which is a way you can prevent any loss of data.
Hope this will help.
CM Punk
This error may happen if the Kernel32.dll file is missing or damaged. To solve this problem extract a new copy of this file from the original windows CD / DVD.
I am giving you an address of a website which may help you : https://support.microsoft.com/en-us/help/146419
shenna22
5 points
Hi good day,
This kind of issue due to some losing file are missing or corrupted file. To resolve this kind of issue try to visit this site for more information:
and read carefully the instruction to fix the issue.
If this kind of issue will not solve, you reinstall your Windows immediately and make new installation of windows system.
The steps to be followed for new installation of windows:
- Restart you computer>Press Delete or F2 key on your keyboard.
- Enter Bios setup then Boot Sequence First boot CD-ROM>Save and Exit.
- Your computer will reboot again and in your screen its say Press any key to Continue and Press Enter.
- The new installation will start.
Note:
Please Read carefully the instruction for installation.
Thank you. Hope it helps.
Shenna22
