alexrods
1090 points
Posted on - 07/18/2011
Hi folks!
My post here is about F-Secure. I met an error a while ago when I started my computer, right after Windows started the error message below appeared. And I am afraid if this will go on, I might be vulnerable by virus attack.
Error loading resources for: file not found.
This all started when I experienced a power outage an hour ago, so my Windows was not shut down properly. When power was restored, after I booted Windows I met the said error. I already re-installed the application, but same thing happens, the same error appeared when I started Windows.
Please share some ideas.
Thanks in advance.
jere366
F-Secure; Error loading resources for: file not found
Hi!
The main problem with system files when not having any backup is the disappearance, those system files are usually very important especially on installation. The best solution here is to go to system restore and restore back to an hour before you installed the application.
I have also experienced a similar problem and the solution I did was to restore my computer hours earlier. Another option is to get a software known as 'recover my files' and once you install and run, search for the file (in this case; fpshx) at that time you lost it. I hope you find this of assistance.
Thanks!
joli.h
Hi!
You have a problem about F-secure.
First check if your F-Secure is installed properly. Whenever this message occurred the problem is always about the installation. When you install any software try to install it in its default path, After installation restart your system. During the booting process don’t click on any item. Even the network icon display at the taskbar.
Uninstall your F-Secure from Control panel, Add Remove program and then be sure from C:/Windows/Program Files that the F-Secure folder is deleted properly or not. Then install the software.
Since the problem started after a power outage in your area that caused your machine to suddenly shutdown then that incident can greatly cause data corruption in your computer because your machine wasn’t properly shutdown.
Check first if it is only F-Secure that got affected by the power interruption. If you are sure that there are no other files or programs having this error then try reinstalling it first since it is the basic remedy that you can do to your program encountering component error.
Uninstall it first then delete its folder from “C:Program Files” to make sure that no files will be left after uninstalling it. After that restart your computer and then install it again. Check if the program will now work. If reinstalling it doesn’t fix the problem, try using other antivirus programs like Norton Internet Security, Norton AntiVirus, or even Kaspersky Antivirus.
If any of these security programs still doesn’t work, then the problem can now be point down to your operating system. Try restoring Microsoft Windows back to its previous state. Restart your computer again then press F8 before the Windows logo appears. Select the option you like or simply select “Last Known Good Configuration (your most recent settings that worked)” from the options and then hit Enter.
