Error LP5 while unpacking program.
I have been trying to run a program from a flash drive with the Ceedo software on my Windows Xp computer. I would like to be able to take this program with me. I haven't been able to get it to run yet. Can you help me out.
Best Answer by Clair Charles
Answered By 0 points N/A #112469
You are asking how to run the Ceedo program that is installed on your flash drive, right? Ceedo is used to access your applications anywhere you are. You will just need to install your applications on Ceedo with just a few clicks.
It doesn't need any technical skills to use this program. It comes with the Windows-like Start menu that you can use to start your applications and installing the apps is just the same on installing it on any computer.
You can watch the step-by-step guide on the link below:
Answered By 15 points N/A #112471
When you say that you want to run the program with you, what do you really mean by that? Is that supposed to mean that you want to run the program from the computer and not from the flash drive? If that is the question, then you will need to figure out what type of application is it, a portable one or one that has to be installed? If it is a portable application, you will simply copy it from the flash drive and place it on the desktop of your computer or the folder location that you will like to place the application at.
If the application needs to be installed, you will need to get its setup and run it on your computer for it to be installed, and then you will be able to use it on the computer.
-Clair Charles
