Winny Poo
Posted on - 12/06/2011
Hi! I have a problem regarding to my Windows Server 2003. First I added provisioning server clients to active directory. Then I created a vdisk. I restarted my computer, and after windows logo this error appeared and the system automatically reboot. What’s wrong?
lsass.exe – System Error
When trying to update a password, this return status indicates that the value provided as the current password is not correct.
Error-lsass exe System Error message
You may have provided conflicting credentials when setting up the active directory in the Windows Server 2003. And since you are not able to access the desktop in the normal boot mode, I will advise that you boot the computer system in safe mode and then try to undo the changes that you may have made.
Once you have booted in safe mode, run the system restore utility as follows to get rid of any changes that might be causing the problems:
Click on the start menu and then type system restore in the search field.
Press Enter on the keyboard.
In the system restore window, specify the restore point and then continue.
Let the process run till it finishes.
When the system restarts, boot in the normal boot mode and see if it works
You can thereafter reconfigure the server but make sure you use the right credentials.
Regards
Thompson Locker
