nasirkhan
Posted on - 09/16/2011
Hi Dear, I want to install Macromedia Contribute 3 but i can't.Because always show a error message when install it. I don't understand what problem happen. Now i need some help for install it. If any wants to help me then write a good answer for help.
"Error 1904. Module C:/WINDOWS/SYSTEM32/Macromed/flash/flash.ocx failed to register. HRESULT -2147220473. Contact your support personnel".
Thank you.
An error in Macromedia Contribute 3 installer
When you are trying to install Macromedia Contribute 3, it is searching for its necessary resource. May be that time this error occurs. If this is the condition then I think you need some supported software for it such as quick player, flash player and many other resources. These options are act like virtual resources for any installation software. So install them first then try to install Macromedia Contribute 3.
Other possibility is may be your installation .exe file is corrupted. In this case you can not install Macromedia Contribute 3 from the same backup. Use other backup such as pen drive, flash drive, optical drive etc and install Macromedia Contribute 3 from there.
