Hall Allen
80 points
Posted on - 10/08/2012
Hey there guys,
I just downloaded Magix Movie Edit Pro and it seemed to have installed smoothly.
However, when I started the program to begin my first project the posted error shows-up in about 5 seconds.
I tried reinstalling it but it’s still the same.
What could be wrong with my set-up?
MAGIX Movie Edit Pro
The program could not be started. It’s possible that the / installation folder is damaged.
Reinstalling the program could remedy the problem.
If the error occurs again, please contact support.
Error code: 4
OK
Error – Magix Movie Edit Pro
This problem happens when there is another version of the software confusing the authentication process. To fix this issue first uninstall the program and delete all the program folder or files related to this software included hidden files like “installation.ini”.
Then download fresh copy or run setup of this software again after restart the system.
This often happens if there is another version of the software confusing the authentication process. So you need to uninstall the program and delete the program files. Some of the these files are hidden. Specifically those installation.ini files that will need to be deleted (which you can find by showing all the hidden files from control panel > Folder options). Now reinstall a fresh copy of your software. After that restart your computer and hopefully the error wont show up again.
