Error message received whenever i try to open up my site.
the operation failed because:
"A domain controller could not be contacted for domain adventistfamilymission.org that contained an account for this computer. Make the computer a member of a work group then join the domain before retrying the promotion.
the specified domain either does not exist or could not be contacted."
What could be the problem.
Best Answer by Edmund Joseph
Answered By 0 points N/A #82552
It could be that your domain name has a duplicate name on the said provider. Another possible answer would be that your domain name is not anymore accessible in the network due to administrative restrictions on the side of your domain provider.
Answered By 5 points N/A #82553
Hi there user:
If you’re using Windows 2008 domain controllers, it would just not install an additional domain controller to join 2003 domain. That’s why this error message appears, ‘A domain controller could not be contacted for the domain that contains an account for this computer.’  Find the Access this Computer from the Network. Do this; manually add the computer account for the new domain controller. And try to test your computer.
Feel free to post again.
Best regards,
