I got the following error message when try to open a remote FTP directory which is not supported by Krusader. I just updated the version but the same problem persists. How can I resolve this issue as I am unable to fix it. I need your help to resolve this matter. Any help would be appreciated. Thanks in advance.
Error –Krusader
Directory/home/dusan/Desktop/test.txt does not exist!
Error message appears while opening a remote FTP directory
Krusader does not support FTP via HTTP proxy. This error may be caused by a mis configuration of the proxy settings in System Settings. Modify the proxy settings to not use HTTP proxy and FTP will work.. And also make sure the file really exists. Try to access another file.
Hi.
For accessing ftp folders with GUI interface on Linux use Nautilus. Nautilus is native file manager on Gnome. One of it`s features is ftp and ssh from the file manager. To use this feature go to File tab and select Connect to server option. In the drop down menu choose how you wan to connect to your remote server and give it`s address, you user name and password. It will open a new windows with your remote folder.
Queen Norman
