Hello experts, I am using Ubuntu 12.10 version OS. I need to install aris flow software into my ubuntu OS. Unfortunately the error message is coming. So please help me to realize this problem. Can you provide me the link to download the aris flow software? Thanks.
Error message from aris flow software
Hello Jefrey,
While installing aris flow software if you are facing problem related to Ubuntu then you must go through these steps.
But if the problem is related to software then you must read installation guide here to install it correctly.
If you need to download the aris flow software then you must search for it on search engine. You will definitely get it.
I hope it will help you resolve your issue.
