Error message: Driver is not accessible the parameter is incorrect
Error message: Driver is not accessible the parameter is incorrect. How can I solve the involving this issue? Can anybody help me to solve this problem?
In order to solve the problem, follow these simple steps:
First, Insert the DVD of your Windows 8 and restart the computer.
Then, hit F12 key, and then choose that drive where you actually inserted the media of installation into.
And, after appearing the window of Windows Setup, follow these simple steps:
First, Click on next and then select the Repair of your computer.
Then, blue screen will appear and you have to choose an option.
Then, click on the Troubleshoot, and then the Advanced Options.
Then, Click on the Command Prompt. And write this command and press enter:
Chkdsk /r
Then Please write Y and then hit Enter.
Hopefully, this answer is helpful, easier and clearer steps to fix the problem.
Boot with Ubuntu.
Try recovering the files.
If this doesn’t work, try the below method
Login with Admin.
Click the start button.
Open Command prompt
And type the following:
chkdsk /F /R /X H:
Where, H= your drive
Note: If “drive inaccessible” message is shown, then, this means that your drive is about to fail or is failing. So do not forget to backup your data.
