Error Message – Excel Cannot Complete This Task With Available Resources 2010
Some times while working in your Microsoft excel 2010 you may encounter the following message excel cannot complete this task with available resources 2010.Rather than the cause what is the solution to this problem?
Answered By 0 points N/A #170195
While working in Microsoft excel 2010 it’s likely that you come across an error stating that excel cannot complete the task due to lack of sufficient resources. Fortunately there are methods to correct them. At the movement let’s talk about the most convenient method.
The easiest solution is to update to the latest version of Microsoft excel available as it contains inbuilt coded for upgrading programme strength and be void of previous versions glitches. Making sure that your excel workbook never exceeds the limit is also mandatory if you have no access to newer versions. Make sure that, the maximum worksheet size limit is 1,048,576 rows by 16,384 columns. The total number of characters that a cell can contain is 32,767 characters. The maximum selected range in a calculation is 2,048.The maximum nested level of functions in a calculation is 64.
These are inbuilt limit capacity for Microsoft excel 2010.Too much information in a single sheet may not prove effective sometimes
