Error Message: “Invalid skin (error in line 0 in the xml)”
Hello!
When I try to run Virtual DJ, I am getting an error message which displays:
"Invalid skin (error in line 0 in the xml)"
Need your help. Thanks.
Hello!
If you purchased the entire DJ system and the problem is only with the application, try reinstalling it. The package ships with the setup CD which allows you to reinstall the software in case it is necessary or install it on a different computer. Uninstall Virtual DJ then click Start, All Programs, Accessories, System Tools, and then select Disk Cleanup.
Select drive C and then click OK. Check “Temporary files” and “Setup log” if available then click OK and then Delete Files. Restart your computer and then install Virtual DJ back. This should fix the issue on the skin. If the problem continues, run Virtual DJ as administrator. Right-click on Virtual DJ on the desktop and then select Properties.
Select Compatibility tab then check “Run this program as an administrator” under “Privilege level” section and then click OK. Start Virtual DJ again.
